Hello!
I'm going to migrate TWX Fun from 9.0 to 9.2.1 + InfluxDB 1.8.4. That's ok.
I have to install the Man Apps 9.1.1 as well, but the related InfluxDB version supported is 1.8.2.
Could you please help me to figure out if:
- is there any known issue using Man Apps 9.1.1 + InfluxDB 1.8.4?
Component |
Current Version |
New Version |
Note |
ThingWorx Foundation | 9.0 | 9.2.1 | Ok |
ThingWorx App (Manufacturing Apps) | N/A | 9.1.1 | Ok |
PostgreSQL | 10 | 12.4 | Ok |
InfluxDB | 1.7 | TWX Found 9.2.1 -> InfluxDB 1.8.4 Man Apps 9.1.1 -> InfluxDB 1.8.2 |
Thanks in advance
Pier
@PGrasso ,
Thank you for submitting your question to the PTC Community.
Currently we only support P/SQL or MS/SQL for the persistence in Mfg Apps and Influx only as an additional persistence provider. For model storage, the only supported backends are the two indicated.
You can read up more on the database configuration steps here: https://support.ptc.com/help/thingworx/apps/r9.1/en/#page/thingworx_apps%2FInstallation_and_Setup%2Fimporting_the_thingworx_apps_extension.html%23wwID0EYTAK
Here is an older thread reading the use of Influx DB for Mfg Apps: https://community.ptc.com/t5/ThingWorx-Developers/Influx-DB-with-Manufacturing-Apps/td-p/618116
Neel
@PGrasso ,
Neel
