There is an Major Disadvantage of the KepServerEX or OPC Aggregators is that, they can only connect to single Industrial Connection of Thingworx. Let's Say there are 3 environments (Dev, QA, PROD). As of now, using three VM's to Connect to each Single Env from KepServerEX.
Isn't a way where all three KepServerEX can be run on the same VM such that VM cost can be Cut ?
@paic @c_lowy @slangley @CarlesColl @VladimirN @AnnaAn
Shashi.
We currently have an enhancement request in our product queue for this kind of functionality; however it's not prioritized for active development at this time. If you have further details about your use-case, as well as your Kepware / ThingWorx footprint, we'd be more than happy to discuss further details with you. Please send to kep-product.management@kepware.com at your convenience!
Thank you!
