Problem with Manufacturing Apps 8.4 trial import DemoFactoryDataSet.zip
ljam
I have installed Manufacturing Apps 8.4 trial and KepserverEx 6.6 but when I am doing Connect Factory Assets Using Control Advisor (Guide 1) in developer portal, I have problems in step 3 when I have to import DemoFactoryDataSet.zip. I attach the images of errors. Could you help me with that?
Thank you in advance
Best regards,
Luis
SebB
(To:ljam)
Hey @ljam
this is a known issue. The Demo Data Set does not work for the 8.4 version.
In the developer portal we still have 8.3 as version for the guys, so the data set is also for 8.3.
Here is a updated version of the Demo Data Set for 8.4
Let me know if you have any issue with the import.
Seb
Seb
Principal Solution Experience Architect
PTC
SebB
(To:ljam)
Hey @ljam
Seb
Seb
PTC
ljam
(To:SebB)
Hola @SebB,
Thank you so much Seb, I haven´t had problems with the import.
Thank you,
BR,
Luis
