Hi @SebB ,
Per this topic:
We're currently using KepServerEX for the MQTT connection.
In Kepware we have data tag in which one string item is in the format as shown below.
"customer": "ABC",
"site": "ABC",
"department": "ABC",
"assettype": "A",
"asset": "A01",
"description": "Make or Model",
"tags": [
"component": "PLC",
"tag": "MachineOn",
"value": 1,
"unit": "1/0-Running/Stopped"
"component": "PLC",
"tag": "Length",
"value": 11.99,
"unit": "km"
"component": "PLC",
"tag": "Temperature",
"value": 45,
"unit": "C"
Since its in this json format i'm unable to use the OOTB Configuration App to directly map Machine status and other properties to the Asset. I've written a Subscription service to parse and map the corresponding properties.
Is there any better workaround for this. Can this heavy lifting part done at kepware side itself.
saran
Hey @SaranKarthick
you should be able to get the values out to the JSON string by using the Tag addresses in Kepware.
I never tried it by my self but in the documentation of the MQTT client for Kepware is a example that looks similar what you try to do. https://www.kepware.com/getattachment/b44c89ac-0b3b-4a22-bdd2-fa7873b38f31/mqtt-client-manual.pdf
On page 17, 18 and 19 are examples.
Seb
Hey @SaranKarthick
Seb
Hi @SebB ,
I'm now able to get the values out of json as expected. The guide was very useful.
Thanks and Regards,
Saran
