Re: Manufacturing Apps reading data from MQTT
SaranKarthick
Hi @SebB ,
Per this topic:
We're currently using KepServerEX for the MQTT connection.
In Kepware we have data tag in which one string item is in the format as shown below.
  "customer": "ABC",
  "site": "ABC",
  "department": "ABC",
  "assettype": "A",
  "asset": "A01",
  "description": "Make or Model",
  "tags": [
      "component": "PLC",
      "tag": "MachineOn",
      "value": 1,
      "unit": "1/0-Running/Stopped"
      "component": "PLC",
      "tag": "Length",
      "value": 11.99,
      "unit": "km"
      "component": "PLC",
      "tag": "Temperature",
      "value": 45,
      "unit": "C"
Since its in this json format i'm unable to use the OOTB Configuration App to directly map Machine status and other properties to the Asset. I've written a Subscription service to parse and map the corresponding properties.
Is there any better workaround for this. Can this heavy lifting part done at kepware side itself.
saran
1 ACCEPTED SOLUTION
SebB
(To:SaranKarthick)
Hey @SaranKarthick
you should be able to get the values out to the JSON string by using the Tag addresses in Kepware.
I never tried it by my self but in the documentation of the MQTT client for Kepware is a example that looks similar what you try to do. https://www.kepware.com/getattachment/b44c89ac-0b3b-4a22-bdd2-fa7873b38f31/mqtt-client-manual.pdf
On page 17, 18 and 19 are examples.
Seb
Seb
Principal Solution Experience Architect
PTC
SebB
(To:SaranKarthick)
Hey @SaranKarthick
Seb
Seb
PTC
Hi @SebB ,
I'm now able to get the values out of json as expected. The guide was very useful.
Thanks and Regards,
Saran
