Redundancy master frequently failed on both OPC services
Hansen_Wij
Does anyone know the reason why redundancy master frequently failed as error reported in the log below
We has redundant OPC client that pulling data from 2 redundancy master.
10/31/2019 2:37:29.902 PM Error AdvDsOPCConnector.exe (3356) Unable to retrieve status for server 'Kepware.KEPServerEX.V6' on primary machine '105.168.4.3'. Server communications has been lost.
10/31/2019 2:37:29.902 PM Information AdvDsOPCConnector.exe (3356) Disconnected from 'Kepware.KEPServerEX.V6' on primary machine '105.168.4.3'.
10/31/2019 2:37:32.454 PM Error AdvDsOPCConnector.exe (3356) Unable to retrieve status for server 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7'. Server communications has been lost.
10/31/2019 2:37:32.455 PM Information AdvDsOPCConnector.exe (3356) Disconnected from 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7'.
10/31/2019 2:38:14.623 PM Information AdvDsOPCConnector.exe (3356) Connected to 'Kepware.KEPServerEX.V6' on primary machine '105.168.4.3'.
10/31/2019 2:38:14.627 PM Information AdvDsOPCConnector.exe (3356) Promoted active connection for server 'Kepware.KEPServerEX.V6' to primary machine '105.168.4.3'.
10/31/2019 2:38:30.949 PM Information AdvDsOPCConnector.exe (3356) Connected to 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7'.
10/31/2019 2:39:09.760 PM Information AdvDsOPCConnector.exe (3356) Monitor item test passed for 'Kepware.KEPServerEX.V6' on primary machine '105.168.4.3'.
10/31/2019 2:39:09.760 PM Information AdvDsOPCConnector.exe (3356) Monitor item test passed for 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7'.
10/31/2019 4:20:11.339 PM Information AdvDsOPCConnector.exe (3356) Received shutdown notification from server 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7'.
10/31/2019 4:20:11.339 PM Information AdvDsOPCConnector.exe (3356) Disconnected from 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7'.
10/31/2019 4:20:25.764 PM Error AdvDsOPCConnector.exe (3356) Failed to connect to 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7' (connect timed out).
10/31/2019 4:20:35.243 PM Information AdvDsOPCConnector.exe (3356) Connected to 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7'.
10/31/2019 4:20:52.808 PM Information AdvDsOPCConnector.exe (3356) Monitor item test passed for 'Kepware.KEPServerEX.V6' on secondary machine '105.168.4.7'.
0 REPLIES 0
