i am trying to use the remote access functionality in manufacturing app.
Web socket server and lua script run on a Raspberry Pi. RealVNC server is installed and running fine.
I am able to do file transfer and the tunneling seem to be working.
However nothing appeared when i clicked on Connect.
My wsems log just say that TUNNEL ENDED without any specific error:
[FORCE] 2018-09-12 12:16:05,970 ./wsems: Initializing EMS .... [FORCE] 2018-09-12 12:16:05,970 main: Using config file /home/pi/Desktop/microserver/etc/config.json [INFO ] 2018-09-12 12:16:05,970 ./wsems: Creating the WsEms proxy. [INFO ] 2018-09-12 12:16:05,970 ./wsems: Starting HTTP Server. [INFO ] 2018-09-12 12:16:05,971 Main: Using built-in certificate for HTTP Server [WARN ] 2018-09-12 12:16:05,971 Main: Encryption is disabled on HTTP Server. [WARN ] 2018-09-12 12:16:05,972 Main: Authentication is disabled on the HTTP Server. [FORCE] 2018-09-12 12:16:05,972 httpServer: [INFO ] 2018-09-12 12:16:05,972 ./wsems: Initializing the ThingWorx REST interface. [INFO ] 2018-09-12 12:16:05,973 wsEmsProxy::initialize: FIPS is disabled. [INFO ] 2018-09-12 12:16:05,973 wsEmsProxy::initialize: Encryption is enabled on Web Socket connection. [WARN ] 2018-09-12 14:16:05,975 SDK: SDK Version: 2.1.2 [WARN ] 2018-09-12 14:16:05,975 SDK: TLS Library: OpenSSL [WARN ] 2018-09-12 14:16:05,975 SDK: TLS Library Version: 1.0.2l-fips [WARN ] 2018-09-12 14:16:05,976 SDK: FIPS Capable [INFO ] 2018-09-12 12:16:06,3 WsProxy::initialize: EMS Version 5.4.2.334 [INFO ] 2018-09-12 12:16:06,3 WsProxy::initialize: twApi singleton initialized [WARN ] 2018-09-12 12:16:06,4 WsProxy::initialize: Certificate validation is disabled. [WARN ] 2018-09-12 12:16:06,4 WsProxy::initialize: Self signed certificates are enabled. [ERROR] 2018-09-12 14:16:06,6 SDK: twMap_Add: parse function returned null. [INFO ] 2018-09-12 12:16:06,9 WsEmsProxy::registerVirtualDirs: Adding virtual dir repo: /home/pi/Desktop/microserver/repository [INFO ] 2018-09-12 12:16:06,9 WsEmsProxy::registerVirtualDirs: Adding virtual dir staging: /home/pi/Desktop/microserver/repository/staging [INFO ] 2018-09-12 12:16:06,9 wsEmsProxy::initialize: Initialization complete! [INFO ] 2018-09-12 12:16:06,11 ./wsems: Starting the connection. xxxxxxxxxxxxxxxxxxxxxx:443-->[ERROR] 2018-09-12 14:16:06,14 SDK: twStream_Delete: NULL Pointer passed in [INFO ] 2018-09-12 14:16:06,121 SDK: Server supports websocket extensions: permessage-deflate [INFO ] 2018-09-12 14:16:06,121 SDK: twWs_Connect: Websocket connected! [WARN ] 2018-09-12 14:16:06,292 SDK: twBindBody_Delete: NULL body or stream pointer [INFO ] 2018-09-12 12:16:06,313 Main: Succesfully connected. Saving .booted config file [WARN ] 2018-09-12 14:16:07,477 SDK: InfoTable precheck: Name "reason" not found in datashape "(null)" [FORCE] 2018-09-12 14:16:15,383 SDK: TUNNEL CREATED. Entity: Asset_PiThing, tid: 81d592c3-03b4-4570-a9a8-994cfe935016, target: 127.0.0.1:5900 [ERROR] 2018-09-12 14:16:15,386 SDK: twStream_Delete: NULL Pointer passed in [INFO ] 2018-09-12 14:16:15,506 SDK: twWs_Connect: Websocket connected! [FORCE] 2018-09-12 14:16:15,506 SDK: TUNNEL STARTED. Entity: Asset_PiThing, tid: 81d592c3-03b4-4570-a9a8-994cfe935016, target: 127.0.0.1:5900 [FORCE] 2018-09-12 14:16:18,314 SDK: TUNNEL ENDED. Entity: Asset_PiThing, Peer: Administrator, tid: 81d592c3-03b4-4570-a9a8-994cfe935016, target: 127.0.0.1:5900
VNC's log say that wsem disconnect by itself.
The tunnel appear in the subsystem
Here is my config.json:
{ "ws_servers": [{ "host": "xxxxxxxxxxxxxxxxxxxxxx", "port": 443 }], "http_server": { "host": "localhost", "port": 8000, "ssl": false, "authenticate": false, "use_default_certificate" : true }, "appKey": "xxxxxxxxxxxxxxxxxxxxxxx", "logger": { "level": "INFO" }, "auto_bind": [{ "name": "Asset_PiThing", "gateway": false }], "certificates": { "validate": false, "allow_self_signed":true }, "ws_connection": { "encryption": "ssl", "verbose": true, "msg_timeout": 1000 }, "file": { "buffer_size": 8192, "max_file_size": 8000000000, "virtual_dirs": [ {"repo": "/home/pi/Desktop/microserver/repository"}, {"staging": "/home/pi/Desktop/microserver/repository/staging"} ], "idle_timeout": 12000, "staging_dir": "staging" }, "tunnel": { "tick_resolution": 5, "buffer_size": 10000, "read_timeout": 100, "idle_timeout": 300000, "max_concurrent": 3, "verbose": false, "duty_cycle": 100 } }
Best,
Bach
I fixed the problem by installing tightvncserver and set tunnel address to 127.0.0.1:5901
Can you try the same by running EMS version 5.3.4 ?
Yes, still the same.
Hi Bach,
Are you able to see the Asset_PiThing as connected in composer ? If yes , then are you able to browse the remote properties of this remote thing ?
If both is working fine , then there is no issue with lua and ems . Then we need to check the vnc configuration .
everything is working, except for the VNC.
The VNC should be running. I am able to do remote using other VNC viewers.
