Hi there,
Has anyone come across or developed an updated version of the Dygraph and Timeline Chart Widgets so that they are responsive.
We have a series of JSON data being streamed in from live assets and these get populated well the existing ootb widgets, but we need these to autoadjust based on the different devices these can be viewed on.
Andrew
Hi @Durbal.Andrew.H,
As per the current product functionality, Dygraph and Timeline Chart widgets are static and have predefined fix width.
If you want to change the width, the widget should be added to a panel, in this case the Width property is visible and can be changed (for example 1024).
Himanshu
Hello, Andrew:
If Himanshu's answer has helped you, could you please mark the question as "Solved".
-Chris Kaminski
