Setup of DCOM configuration - manual doesn't fit reality
AP_8806927
3-Visitor
I'm trying to setup DCOM consiguration as explained in section 4.1 Configuring the Application at https://www.kepware.com/getattachment/04042e47-c690-467c-a931-a1ca126575db/Remote-OPC-DA-Quick-Start...
But, I don't see entry on "OPC Server".
Because of that, I can't connect to Kepware OPC server from other machine.
1 ACCEPTED SOLUTION
Greetings,
So the 'OPC Server' is just a placeholder for what the DCOM entry is for whatever OPC Server you may be using. In the case of the current release of KEPServer, the entry is 'KEPServerEX 6.9'.
Kind Regards,
Andrew Black
Senior Technical Support Engineer
2 REPLIES 2
Greetings,
Kind Regards,
Andrew Black
slangley
23-Emerald I
(To:AP_8806927)
Hi @AP_8806927.
If the response provided in the previous post answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
