Shift Configuration in Mfg Apps
koushal
Hi All,
I am using Thingworx Mfg Apps 8.4.0. I see the Shift Start Time and Shift Duration as asset properties which are configured via  Planned Operation time Start and Duration in Configuration and setup tile. I wanted to understand how this works. Whether this implies that I can have only one shift in a day. If not how can i configure for multiple shifts. Also is there any mechanism to configure the break timings in a shift?
Please provide your inputs.
1 ACCEPTED SOLUTION
geva
(To:koushal)
Check out this help centre page about setting up shifts and schedules for KPI calculations.
https://support.ptc.com/help/thingworx_apps/r8.5/en/#page/thingworx_apps%2FThingWorxAppsCust%2Fconfi...
I do not believe that there is presently support for breaks.
5 REPLIES 5
geva
(To:koushal)
koushal
(To:geva)
hi,
Thanks for your response.
Can we do shift configuration in 8.4 or is it available in 8.5 onwards?
One more question,
I see the status timeline for Asset in Asset Advisor Mashup. Can you please let me know where are we storing the data for Asset Status. I know that we are defining the machine status as an expression in Configure and Setup Mashup. Please let me know if any document available from which i can get to know more about how asset status data are stored and retrieved?
ganeja
11-Garnet
(To:koushal)
Hi @koushal ,
Shift configuration is available form 8.5 onwards.
I hope below link address your another question:
https://support.ptc.com/help/thingworx_apps/r8.5/en/index.html#page/thingworx_apps/ThingWorxAppsSetu...
Gunjan Aneja
slangley
23-Emerald II
(To:koushal)
Hi @koushal.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community!
Regards.
--Sharon
slangley
23-Emerald II
(To:koushal)
Hi @koushal.
I have marked the Accepted Solution for this post.  If you disagree with my choice, please let me know.
Thank you for your participation in our community.
Regards.
--Sharon
