Hi @Abhinav_Indana ,
You need to edit the static property from the composer, change type from "My Property" to "Local Bound" and add the Thing/Property Name in Property Bindings. Make sure to check the Persistent and Logged values as required
Himanshu
If the above response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Himanshu
