ThingWorx Apps Manufactor
RaulBernardo.PV
11-Garnet
How to install ThingWorx Apps Manufactory extension step by step? Would it be possible to install with 8gb of RAM?
Translated by the Community Moderation using Google Translate
Como instalar a extensão ThingWorx Apps Manufactory passo a passo? Seria possível instalar com 8gb de RAM?
What you can do, first of all determine how much memory your actual OS needs, then go into the JVM Java options and set the xmx to the highest you can afford to give the JVM without crashing your server. That's probably the best you can do. Hypothetically, if for example you can run on 2GB and right now the JVM thinks it is limited to using 5GB, you can set xmx to 6GB and see if that is enough to make the install run successfully.
6 REPLIES 6
Not sure exactly which pieces you are looking to install, but I believe each of these have their system requirements listed?
If  you are talking about the original TWX Manufacturing Apps, Also the installation steps should be within the appropriate help center.
Else you can start your search on Support.ptc.com
Thanks for answering me ! In fact, I wanted to know if there is any way to install TWX Manufacturing Apps on a computer with only 8GB of RAM memory, because whenever I go to import the extensions it keeps looping and cannot load.
Obrigado por me responder ! Na verdade eu queria saber se existe alguma forma de instalar TWX Manufacturing Apps em um computador com apenas 8GB de memoria RAM , pois sempre quando vou importar as extenções ele fica em looping e não consegue carregar.
Thanks !!
Obrigado !!
Hello ,
After configuring java I was able to enable an extension process but now I'm having trouble importing Thing worx - APPS -9.1.1-00 - extension-dependencies.zip.
I was able to do the whole process of enabling the extension package in PlatformSettings-Json by setting everything to true , and also importing the MED-61284-CD-091_SP1_Remote-Access-Extension-3-1-4.zip extension.
Only when I import this extension: ThingWorx-Apps-9.1.1-00-extension-dependencies.zip gives an error. It validates but it doesn't matter
Olá ,
Após configurar o java consegui habilitar um processo da extensão só que agora estou com problema para importar o Thing worx - APPS -9.1.1-00 - extension-dependencies.zip.
Consegui fazer todo o processo de habilitar no PlatformSettings- Json o pacote de extensão colocando tudo para verdadeiro , e também importar a extensão    MED-61284-CD-091_SP1_Remote-Access-Extension-3-1-4.zip.
Somente quando vou importar  está extensão :ThingWorx-Apps-9.1.1-00-extension-dependencies.zip dá erro .Ela valida mais não importa
What is recorded in the Application log about the error or the script log?
