Dear All,
I want to set up a new server PC for Manufacturing Apps. Do I have to redo the entire configuration or do I have any chance like backup?
Salih Güneş
Greetings @salihgunes,
If you are setting the new server then you need to configure it again.
You can import/export the entites/data from one server to another using Import/Export functionality in ThingWorx Composer.
Himanshu
Himanshu
