we updated our Thingworx Instance from 8.4 to 8.5.2 and Manufacturing Apps to 8.5.1. After this update we experienced an error that our Assets after a reimport are not showing up in the Asset Advisor.
State after Update from 8.4 to 8.5.2:
- 5x Assets in Asset Advisor visible
What did we do:
- Delete asset / extension in Composer
- Reimport asset via custom extension (ZIP File)
- Import successfully -> asset visible in Compose
- Asset not more visible in Asset Advisor / Manufacturing Apps
Workaround to get Assets visible again:
- Create a new asset with the same name in "configuration and setup" in manufacturing apps
- Reimport the same Extension (contains Assets) and overwrite new asset
- Now the assets are again visible in Asset Advisor
Questions:
- Is there a fix for this problem, without the workaround?
- How do I deploy assets to different thingworx instances without the above error?
Hi @benjaminlhind ,
Are you using any custom template for assets/lines on your instance.
Please share the screenshot of the Asset Advisor screen, Custom Launchpoint configuration tab screenshot and the application logs for the timestamp when error occurred.
Himanshu
Hi @benjaminlhind.
If you have found a solution to your problem, please post it here for the benefit of others on the community. If you still need assistance, please respond to Himanshu's post.
--Sharon
There is a Network entity that you have to add your Assets into for them to show up in the Apps. We migrated from 8.4 to 9.1, and I believe the Network was called "PTC.Factory.PlantNetwork" in both instances. You might be able to simply migrate the Network along with your assets.
