I'm wondering when "Thingworx SCO Utilities Subscription" license is required?
I can't find any detail explanation on this license.
If customer want to manage IoT platform as central hub providing supply chain data from multiple sources (ERP, MES, LIMS...), should I add this license?
Thank you for posting your question to the PTC Community.
The SCO Utilities Subscription license is for use of PTC Manufacturing Apps / Operator Advisor.
If you need additional assistance with licensing, I would recommend that you open a case detailing your issue so that License Management expert can assist you directly.
Neel
Neel
Hi @AC_8918918.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
