Hi ,
I'm trying to setup a Thingworx composer with Mfg Extensions along with demo data.
Can anyone help me out with getting the sample data for Mfg app's.
Thanks In Advance
Umar
Hi @javeed420,
You can find the demo data on PTC learning connector. Below is the link from where you can it.
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Himanshu
Hi @javeed420,
Himanshu
Hi Himanshu,
When I'm trying to import the entities zip file / after extracting it, I was getting the below error. I think it was asking for a template which is not in the DemoSimulatorPackage , can you help me out in resolving this issue.
Error importing: , Unable to Invoke Service ImportSourceControlledEntities on SourceControlFunctions : Import Failed: Thing ValueStream_Line_1b563bcd-a12e-4b84-b45e-70ce8cf27f90 has an invalid thing template [PTC.Factory.EquipmentValueStreamTemplate]
JaveedUmar
i have the same issue , did you solve it
Guys,
what Thingworx and Apps version are you using?
Here is another link where you can download the data set with detailed instructions how to import the demo data set:
Seb
