Why it not show anomaly status
Nuttapol
11-Garnet
I use MFG version 8.0
I would like to do anomaly in asset advisor
What i should to do please suggest me
MFG installs only Anomaly Detection which are two micro services.
7 REPLIES 7
hrajpal
(To:Nuttapol)
Greetings Nuttapol,
To use the anomaly , you need to configure the anomaly alert to the asset's property and also make sure all the services are up and running for ThingWorx Analytics Server.
Himesh Rajpal
You mean i must install Thingworx analytics server for use with MFG ?
hrajpal
(To:Nuttapol)
Only the microservices of analytics i.e Thingwatcher ( If you are using MFG as extension to Thingworx platform )
Prior to Thingworx Manufacturing 8.1.2, Anomaly detection will install by default. However you will require enterprise license to use it. Starting 8.1.2, Anomaly detection will be disabled by default. You need to configure them to make it available. You will still require enterprise license.
I hope this helps.
Varathan
Also check your license to see whether you have anomaly detection added. If you are using Freemium version, you will not have it.
Varathan
@vranganathanI use partner license
