I want to build the dashboard as per my requirement in thingworx manufacturing app.
is it possible in thingworx manufacturing app ?
Nikita,
I believe you have proper licensing to access Composer. The Freemium version doesn't allow it. You need to use either Developer Version if you are using trial version. In case of licensed versions either Premium or Enterprise license will do.
Varathan
Greetings Nikita,
ThingWorx Manufacturing Apps is an extension which runs on ThingWorx Platform , so you can build the dashboards too using the functionality of platform via ThingWorx Composer
Himesh Rajpal
Nikita,
Varathan
