I would need to now if and how is possible to change background color for whole header in Manufacturing Apps Masters.
I followed the customization guide, its possible to change PTC.Factory.C_MasterMashupTile_<release> in regards to logo and background color. But that is only half of the page. Rest is directly in Master which does not have a duplicate and it cannot be changed.
I only can make a copy of it, I have found out that color can be set at Master's Header's right panel.
But how many Masters do I need to copy and which mashups are using those Masters?
Is there a way how to achieve this?
Hi @tcoufal ,
It is not possible to change the header background color as you specified with the existing design because there are different master mashup for all the tiles/mashups and these are defined in the services which are executing at mashup load.
Customization can be done upto a limited extent which is defined in the customization guide and we can change the logo in the header only.
Himanshu
Hi @tcoufal ,
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Himanshu
Agreed..If u wanna change the header of only specified portion,not possible..U need to select the entire portion of a system DQFanFeedback
You can watch youtube tutorials or u are welcome to go to GitHub and ask the pros there.
regards,
Talktosonic
