kepserver migration
BM_9155657
kepserver migration
I am trying to migrate kepserver from a 2008 windows server to a newer version.  Is there any kind of article on how to do this?
We currently have ~ 30 towers setup with 1 to 60 devices per tower so ideally we can migrate all the tower ip / device group / address in one action.
Also, not sure if this helps answer the question but we primarily use Fisher / Lufkin Modbus / EFM exporter.
Thanks for the help or any support links you think would be good for review.
KCorrigan
(To:BM_9155657)
Greetings,
The following KCS article includes the steps for migration including the licensing steps VladimirN mentioned AND how to save your entire KEPServerEX Configuration as a .opf project file for opening in another Server instance:
https://www.ptc.com/en/support/article/CS346293
BRgds,
KC
Here are some helpful articles:
P.S. "My Kepware Portal": https://my.kepware.com/mykepware/
BM_9155657
(To:VladimirN)
Thanks, that will be helpful for license migration. Any idea on how to move the actual config? We have hundreds of devices on roughly 30 towers. I am trying to avoid manual configuration / coding against api to replicate the structure we currently have setup. Thanks.
KCorrigan
(To:BM_9155657)
Greetings,
BRgds,
KC
