there is a data stream from the robot. the data changes, but the data in the stream is not updated. how do I make the stream auto-update?
Greetings,
If you launch the OPC Quick Client, KEPServer will attempt to reach out to the device and retrieve data from the device. Without a client connected, KEPServer does not read any tags.
If you need further assistance with troubleshooting, Please submit a support ticket and we would be happy to assist.
Kind Regards,
Andrew Black
What PTC's software do you use?
I am currently using Kepware ptc software.
Greetings,
Kind Regards,
Andrew Black
Hi @VV_9645121.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
