drawing dimension problems
üşahin
1-Newbie
Hi;
I am not satisfied with the Creo 3.0 M50 drawing dimensioning practices. Because use of the Ctrl + mouse ball moderate difficulty was created not ease.
In this old type of application or a more appropriate method of application would need to be carried out are need for
Best Regards
Ümit Şahin
2 REPLIES 2
wcone
1-Newbie
(To:üşahin)
We recently upgraded to 3.0 and I have a complaint about the dimensioning.  On 2.0 if you clicked dimension you would click one line, click second line and then center mouse to place the dimension.  Now, we have to hold the ctrl button after you click the first line. Is there any way of turning the Ctrl button portion off?  For me, it really slows me down if I’m going through not using the Show Model Annotations tab.
Thanks, WES
Sounds like the way to do measurements in Creo 2..  pick a feature, hold the CTRL key & pick your 2nd feature..  Cumbersome..
