model manager web client
SE_10539318
I have installed the Creo Elements Direct Manager Server. All functions are working properly. However, despite having a license, the web interface is giving an error. I believe it's using a Jetty server. There might be something missing or incorrect. I would appreciate any help on this matter.
Hi @SE_10539318,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
lfortner
(To:SE_10539318)
Are your web services up and running ?
Did you check using "Manager Server 20.7 Java Services Manager" ?
How are your "Direct Manager Server 20.7\logs" ? JettyServer.log, JettySlave1.log, etc
Sometimes you need to try logging several times before success.
Thank you for answer. I will check
