BSP THREADS IN THE HOLE FEATURE
awright-2
8-Gravel
Hi all,
I wonder if anyone can help me out with this hateful piece of software. I am trying to put an 1/8BSP tapped hole in for a part. In the hole tool I have the options of ISO, UNF and UNC thread classes and BSPT, NPT, or NPTF if it was a tapered hole. Why not BSP? God I wish I could go back to Catia where things work as you want them too.
BenLoosli
(To:awright-2)
The hole files are just text files, create your own for BSP.
I have found that the drill diameter PTC uses for their hole files does not align with standard drill sizes for all holes. I have edited the files many times to get the proper data needed for manufacturing.
BenLoosli
(To:awright-2)
Ok, how do you get to the text files to add new data?
BenLoosli
(To:awright-2)
The hole files are in <Creo_loadpoint>\Common Files\text\hole.
BSP.hol would be a valid name.
Look at the other files o get a feel for the file syntax.
