If i create a part(.pkg) i get a geo resolution of 1.0E-6 mm.
But when i import a part to creo, for example in .step, always get a geo reolution arround 1.6E-2 mm.
The company that i work for as a module that allows me to compare the active part to the database, and returns me the part with more similarity. But this only work if a the part has a geo resolution of 1.0E-6 mm.
Is any way to work arround this? i want to use this module with imported parts, but i cant becouse i have a geo res of 1.6E-2 mm.
Creo Elements Direct 20.2.1.0
Thanks!!! It worked!!
