Countdown for connetion
TeoB
"Creo Direct / Elements Modelling Express"
when turn on my sotware, a label shows me a countdown about the connection. Why? I have some limitations in "Express" version?
Thank in advance
***** I use Creo Elements/Direct Modeling Express 8.0 *****
TeoB
(To:highway45)
Hi Highway45,
Thanks for your confirm
Bye bye
Preview
Kotom-Eng
(To:TeoB)
When you turn off internet on your pc, you can still work with "Express" during 72 hours.
These last days, I got the same message. Usually, it is a problem on PTC side (unless you changed your proxy configuration). The problem will be solved in some days.
Click on "Submit", "Express" should start again after a few minutes.
http://kotom.eng.free.fr
TeoB
(To:Kotom-Eng)
Hi Kotom-Eng,
thanks for your answer. I tried to ask an activation from PTC and I have received a code. Now It restarted and I will check the next status.
Bye and have a nice day
TeoB
(To:TeoB)
Hi guys
I confirm that the licence of "Modelling Express" is only for 72 hours.
After them, it must to ask a code of attivation for other 72 hours and I think, that there is not limitations for the number of request.
I will informe you about other conditions
Bye bye
highway45
(To:TeoB)
No worry, this is true.
Over the years I did this an infinite number of times.
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
TeoB
(To:highway45)
Hi Highway45,
Bye bye
Preview
