"Creo Direct / Elements Modelling Express"
when turn on my sotware, a label shows me a countdown about the connection. Why? I have some limitations in "Express" version?
Thank in advance
Hi Highway45,
Thanks for your confirm
Bye bye
When you turn off internet on your pc, you can still work with "Express" during 72 hours.
These last days, I got the same message. Usually, it is a problem on PTC side (unless you changed your proxy configuration). The problem will be solved in some days.
Click on "Submit", "Express" should start again after a few minutes.
Hi Kotom-Eng,
thanks for your answer. I tried to ask an activation from PTC and I have received a code. Now It restarted and I will check the next status.
Bye and have a nice day
Hi guys
I confirm that the licence of "Modelling Express" is only for 72 hours.
After them, it must to ask a code of attivation for other 72 hours and I think, that there is not limitations for the number of request.
I will informe you about other conditions
Bye bye
@TeoB wrote:there is not limitations for the number of request.
No worry, this is true.
Over the years I did this an infinite number of times.
Hi Highway45,
Bye bye
