Can anyone tell me how to upgrade my Creo Elements Direct Modeling Express? I had been running the free version on a laptop that I replaced and when I loaded Express on the new laptop I got version 8.0. The old laptop has 6.0. I occasionally run the old laptop in my shop to check a model and can't share a model between them due to the difference in versions.
https://www.ptc.com/en/products/creo/elements-direct/modeling-express
Just to understand your problem: can't you load version 8.0 on your old laptop ?
My question is does the program ever update on it's own, or if not how do I manually update it to the newer version. I want to get both machines up to version 8.
It does not update automatically.
You have to download and install another version manually.
I had an issue getting to the download. I got to what I thought was the correct webpage to get the download, but couldn't get the download to work. Can you give me the address to the download?
Version 80.0.24.0 x64: https://www.ptc.com/-/media/Files/creo/elements-direct/64-bit/ModelingPE__setup_EN.exe
And if you like to take over your existing customization you can give it a try by copying all files from
This is working in most cases.
