Creo Direct Direct Modeling Express upgrade to latest version
RJH1984
Can anyone tell me how to upgrade my Creo Elements Direct Modeling Express? I had been running the free version on a laptop that I replaced and when I loaded Express on the new laptop I got version 8.0. The old laptop has 6.0. I occasionally run the old laptop in my shop to check a model and can't share a model between them due to the difference in versions.
8 REPLIES 8
VladimirN
(To:RJH1984)
Try looking at the old link in the web archive: https://web.archive.org/
Just to understand your problem: can't you load version 8.0 on your old laptop ?
http://kotom.eng.free.fr
RJH1984
(To:Kotom-Eng)
My question is does the program ever update on it's own, or if not how do I manually update it to the newer version. I want to get both machines up to version 8.
highway45
(To:RJH1984)
It does not update automatically.
You have to download and install another version manually.
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
RJH1984
(To:highway45)
I had an issue getting to the download. I got to what I thought was the correct webpage to get the download, but couldn't get the download to work. Can you give me the address to the download?
VladimirN
(To:RJH1984)
memyself
(To:RJH1984)
And if you like to take over your existing customization you can give it a try by copying all files from
  • "%APPDATA%\PTC\Creo Elements Direct Modeling Express 6.0\60.0"
    to
  • "%APPDATA%\PTC\Creo Elements Direct Modeling Express 8.0\80.0"
This is working in most cases.
● PE6+8@home ● W10 Pro Build19045.3448 ● Drafting V20.1-5 ● Modeling V20.1-5
