Hello friends,
In Creo Elements Direct Modeling 19.0, how can I measure distance between the axes of two holes?
Every time when I want to measure the distance between axes of two holes, I only can get the minimum distance between two holes.
And you have to take the function "point to point".
Not "surface to surface".
Before clicking the circles, hit [CTRL][SHIFT]. That will select the center of the circles.
Hello highway45,
Thank you, this issue had troubled me for a long time, and you have successfully helped me solve it, many many thanks.🤝
Hello Kotom-Eng,
Many many thanks for your warm-hearted help.🤝
