This is more of a suggestion than a question!
PTC Crew....
My idea is to have a delete button at the edit bar of any feature. This idea came to mind because many in times whenever I'm editing a feature and I realize that it is no longer needed I am forced to click at least 4 times to actually delete it.
And with the Delete button it would require just 2 clicks.
You can submit your idea here - "Creo Elements/Direct Ideas": https://community.ptc.com/t5/Creo-Elements-Direct-Ideas/idb-p/creoelementsdirectideas
The problem is that I am not able to submit/suggest an idea. The "Suggest an idea" is not enabled to me!
