Issues with anim_create_animation
ThomasS2
11-Garnet
i have some issues with the dialog "anim_create_animation". For some reason i can not delete the selected object-list. Is this a known issue?
If the names of the objects have a certain length and you select the objects in the drop-down menu, then the program crashes.
Software/Version: Creo Elements/Direct Modeling 20.3
0 REPLIES 0
