It will only get the properties of the active part or face
Gerard_Moba
This solution is not working as expected. It will only get the properties of the active part or face
To get the properties of the selected part or face use: (where mypart or myface is defined in the sd-defdialog)
(get_vol_prop :for_part :part mypart :area)
(get_vol_prop :for_face :face myface :area)
(get_vol_prop :for_part :part mypart :tol :percent_tol 5 :area)
 See
Integration Kit GET_VOL_PROP
Integration Kit GET_VOL_PROP MPPASA subaction
Integration Kit GET_VOL_PROP MPFSA subaction
Hi @Gerard_Moba,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
