What rendering software work best with element direct.
Opyone
I am looking to do some rendering but element direct PE dosent have any software intergrated.
So what software do you recommand to do realistic rendering?
6 REPLIES 6
wvangeem
(To:Opyone)
Keyshot is a great program. A lot of CAD vendors use Keyshot as an engine for there renderings.
This will also be implemented in Creo 4.0 I believe.
Keyshot can load .stl files.  It will work well with Express.  We use Keyshot for advanced rendering.  I have a full version of modeling and the built in rendering is very good for most presentations.
Tom
Creo Element\Direct Modeling 20.6.0.0.0
MaxR.Kublin
(To:Opyone)
What do you mean by "PE"?   Express Version? or something different?
Im am not sure if Keyshot works with the Express Edition.
I am using Modelling Express, is it ok with it?
How the import works? iis the definition of the surfaces ok?
wvangeem
(To:Opyone)
Hi, I suggest you install the trial version of Keyshot (for 14 days I think).
It's really easy to use.
Check what files you can export using Modeling Express. If you can save STEP or STL, you're fine.
Opyone
(To:wvangeem)
did you try blender?
