flat view attributes
rvanveerdeghem
11-Garnet
Does someone know how to inquire the :base_face, :flat_origin and :flat_direction of a flat view in annotation. I tried to do it with (sd-am-inq-view), but I can't find these things. We already create one flat view, but we want to have a sheet with a second flat that is completely the same like the first flat. So it would be handy to get these attributes out of the first one.
Does somebody know how to inquire this?
thanks in advance
(DOCU::DOCU-GET-FLAT-INFOS "~21")
Where "~21" is the unique drafting part number, this will return a complete structure of the flat view eg.:
(:GENERATE-STRING
  "( SHA_UNFOLD :BASE_FACE (SHA-GET-FACE-BY-SYSID \"093551-1431716069-1c42c54d36-0 759\" \"093551-1431716069-1c42c54d36-0 2434\") :LIST_ERROR_MESSAGES_ONLY :ON :LOCAL_FLAT_ORIGIN 94.0,2.0,0.0 :LOCAL_FLAT_DIRECTION -1.0,0.0,0.0 :OUTPUT_TO_VP :OFF :OUTPUT_TO_ME10 :ON :FILENAME :OFF :SUMMARY :OFF :BEND_ALLOWANCE_SHOP :CONE_BEND_ALLOWANCE_SHOP :SHARP_BEND_RADIUS 0.4 :DOCU_VIEW_NAME \"sha-flat1\" :SD_V \"093551-1431716069-1c42c54d36-0 1365504905\")"
  :PART-SYSID "093551-1431716069-1c42c54d36-0 759"
  :FACE-SYSID "093551-1431716069-1c42c54d36-0 2434"
  :SHOP-NAME "demoshop" :ENV-STRING
  "(mbu_set_flat_environment 0.4 0 16711680 255 255 32768 16711680 32768 16711680 32768 32768 16744448 16744448 32768 16711680 32768 16711680 32768 32768 32768 16711680 32768 16711680 32768 32768 0 1 3.5 0 0 0 0 0 T T T T 0 \"sha-flat\" T NIL 0.5 \"UP\" \"DOWN\" \"R\" \"ANG\" 3 3 T NIL NIL NIL T T T T 8421631 15132390 T T T 1 7 T T T T 8421631 15132390 NIL 16711935 16711935)"
  -1.0,0.0,0.0 :BEND_ALLOWANCE_FIXED NIL :CONE_ALLOWANCE NIL
  :SHARP_BEND_RADIUS 0.40000000000000002 :DOCU_VIEW_NAME
  "sha-flat1" :SD_V
  "093551-1431716069-1c42c54d36-0 1365504905")
(:GENERATE-STRING
  "sha-flat1" :SD_V
