How can I load a sketch via command line that is placed as a child of the frame?
In my case I would like the "logo" sketch to be placed as a child of the "cart_A3" frame
the command line command to load the sketch is:
sd-am-load-sketch
I' have Creo Elements/Direct Modeling 20.5.1.0
(sd-am-load-sketch :file_name file_name :position position :owner_type :current-frame :owner owner <- you do not need this if you set the owner_type to :current-frame. :adjust adjustment)
:current-frame
:owner_type
:owner field
:upper_left :upper_middle :upper_right :middle_left :middle_middle :middle_right :lower_left :lower_middle :lower_right
Hi @AR ,
I wanted to see if you got the help you needed. If so, please mark the reply as the Accepted Solution. It will help other members who may have the same question.
