While Creating Tag in Thingworx 8.0.1 if we mention some additional comment in description section it gets reflected in Term. For eg. If I create a tag with name "Demo" and in description if I write ant comments using <> or "" characters then same is getting reflected in Vocabulary while selecting tag term. For your reference attached are 2 screenshots. When no description is added then it works fine but issue occurs when we write additional description.
Thank you for finding this; TS team will investigate and report back.
Created a Jira PSPT-3941.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS267713&lang=en_US
