2014 KOP
SOLVED
Highlighted
Visitor
2014 KOP
Nudge, nudge
1 ACCEPTED SOLUTION
Highlighted
Re: 2014 KOP
Hopefully you found it at 12:00pm EST @ www.ptc.com/go/firstkop.
I was also notified there are some missing files! My mistake. I am working with CDS on this now. In the mean time, please use the attached ZIP for a full Creo assembly of the LONG and WIDE AndyMark 14U chassis configurations. Be sure to look for the PVZ files to quickly review the assembly in Creo View
06-JAN-2014: Updated attachment with renamed toughbox_mini_assy.asm in the ZIP.
7 REPLIES 7
Highlighted
Re: 2014 KOP
Re: 2014 KOP
Yep! Thanks Scott!
Highlighted
Re: 2014 KOP
Hmm, "touCHbox_mini_assy.asm"...interesting take on the name of the "touGH box"
Highlighted
Re: 2014 KOP
Ooops, typo on my part. Got the parameter right, got the filename wrong. I will update the filename with the next KOP revision later this week. For now, please rename with either the wide, long or both AM14U chassis in session. If you rename it in Windows (outside Creo), the top level long and wide assemblies will not be able to find the original assembly any more.
Highlighted
Re: 2014 KOP
Thought PTC was getting creative with the naming of parts.
I can see some of those assembly constraints on the Toughbox are a little "creative"
Highlighted
Re: 2014 KOP
Yeah, I still need to work on that. Want to have a fully functional drivetrain with gear pairs and belt connections, but ran out of time early Saturday morning. I hope to fix it up this week if I can find the time outside of game brainstorming.
Highlighted
Re: 2014 KOP
Big thanks to Scott, Jordan, Chris, the engineers at FIRST and CDS for making this happen! I am pretty sure this is the earliest we have been able to make the full kit of parts and field of play available.
Welcome to PTC Academic!
