On, 24th August 2014, after installing Creo 2.0 student edition when I started the "Creo Parametric 2" it gives a error message like below
"Fatal error encountered. A traceback has been written to C:\Users\Public\Documents\traceback.log
Please send it to Technical Support"
Please help me to solve this so that I can use Creo 2 smoothly.
Hi Mohammad,
This is a relatively common issue at this time with certain Intel graphics drivers. Here's how to fix it...
If you are interested, an extended write of of the issue is located here: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS156839
Hi Mohammad,
