About Error after Installing Creo 2.0 student edition
ptc-6360605
1-Newbie
I have downloaded the creo 2.0 student edition, after installing when i open software the error is came, fatal error and software is not open ,
please anyone tell me what is the solution or how to fix it?
Foloowing snap shot is the window of that error
1 ACCEPTED SOLUTION
MarkCheli
6-Contributor
(To:ptc-6360605)
Hi All,
For any that may be looking at this post after the fact (such as via a google search), there is an updated solution available.
Please see the post below for more information on this...
http://communities.ptc.com/thread/56357?tstart=0
6 REPLIES 6
MarkCheli
6-Contributor
(To:ptc-6360605)
Hi Anup Patil,
It does not appear that a snapshow has been included? My recommendation would be to download the most up-to-date version (M110) from the below link and re-install.
https://support.ptc.com/appserver/auth/it/esd/academic.jsp
There was an issue on some computers with version M100 but that should be fixed in this latest release.
Thanks!
I have installed completed Creo M505 student with no errors,but when the first scense, i taked the screen photo for you to check,I can not access to use. ( as the attchment)
Please help me,
The trace creation timestamp is: Thu Jul 31 20:27:41 14
The executable build timestamp is: Wed May 14 23:43:16 14
The datecode is: 2014090
The pro machine type is: x86e_win64
The process ID is: 3936
The traceback type is : CRASH
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 4352.
Main Thread 4352
MarkCheli
6-Contributor
(To:ptc-6399824)
I'm not sure i'm uderdstanding the problem you are experiencing. Could you please elaborate for me please?
Have you found the solution? I have the same problem. I appreciate any help
MarkCheli
6-Contributor
(To:ptc-6434851)
HI Victor,
You can see informaiton on how to fix it below...
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS156839
If you would like more direct support or you are having trouble with the fix, please submit a support request using the below link...
http://support.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
MarkCheli
6-Contributor
(To:ptc-6360605)
Hi All,
