I am using the following URL to get started with ThingWorx.
Fundamentals of IoT Development with ThingWorx | Udemy
While trying to execute "Academic Edge Connector.exe", I get following error:
Could not find main class: ui.ThingWorxConnection. Program will exit.
Any help/pointers will be appreciated.
~Naresh
NARESH CHAURASIA: On which OS( Windows, Linux , MAC ?) you are running the "Academic Edge Connector.exe" .
Did you tried running the executable as administrator ?
I opened command prompt as administrator and tried to run the exe file. I am still getting the same problem.
Mark Cheli is this something your team could assist with? Thank you.
I am able to login using the jar file for linux, using the following command...
java -jar AcademicEdgeConnector.jar
~Naresh
Hello Naresh,
I suggest you take a look at this PTC University Forum entry: https://forum.ptcu.com/t/thingworx-academic-simulator-not-connecting-with-thingworx/252/12
