After successful installation of Creo 3.0 Student Edition, the application failed to open and I got the following error message: shutting down because.... could not the run Quality Agent which is required in this edition,,, error 0x06000012
How do I resolve this error which shuts down the application  after a successful installation of Creo 3.0 Student Edition. Error message reads..... " Cannot run Quality Agent ....."
Attached below is the screen shot of the error message.
Re: After successful installation of Creo 3.0 Student Edition, the application failed to open and I got the following error message: shutting down because.... could not the run Quality Agent which is required in this edition,,, error 0x06000012
I have the same issue!
Please, help us!
same problem here also.please help us.its disgusting so much.
Please try following the guide below to see if that solves your issue:
http://apps.ptc.com/schools/references/support_creo2_qa.pdf
Chris
