Are the CAD files available for the Res-Q playing field?
SOLVED
Granite
Last year's field model was available almost right away.  Thanks
1 ACCEPTED SOLUTION
Highlighted
Re: Are the CAD files available for the Res-Q playing field?
We found the CAD models for the field on the Andy-Mark website.  Link below.  Just click on the "Files and Documents" tab and the CAD files will be there.  Also keep in mind that the CAD files are in the STEP format.
RES-Q Full Field Set
Trevor A. Babb
FTC 8521
4-H Hard-Hitting Hardware Hooligans
4 REPLIES 4
Highlighted
Trevor A. Babb
FTC 8521
Highlighted
Thanks Trevor!
STEP works fine
Highlighted
Your welcome!
Highlighted
As always, the FTC Fields and FTC KOP's are available from PTC @ Software | FIRST | K-12 Program | Academic Program | PTC.
Welcome to PTC Academic!
