Blue Prints in ProDesktop
Highlighted
Newbie
I have just started using ProDesktop 2000i2 and was wondering is it possible to use blue prints in it, if it is could you tell me the steps to go through as I have only just getting start and would like to make a E30 M3 using a blue print but I need help. Thanks.
3 REPLIES 3
Highlighted
RE: Blue Prints in ProDesktop
Hi Sam, I will need a little more information. Are you looking at creating drawings in Pro/DESKTOP? this is certainly possible, based on a 3D model you create. I am not sure what you mean by 'use blue prints in it'. Blue Prints are typically the hard drawing that was created on vellum and transfered to paper media. The transfer process generated the blue effect and thus the name blue print. Can you please provide more details? Mark
Highlighted
You can import sketch geometry into Pro/DESKTOP and have it imported onto a specified sketch/workplane. But you can't import an image file (i.e. bitmap/jpeg etc.) into Pro/DESKTOP. you can do this in Pro/ENGINEER Schools Advanced Edition. MJB
Welcome to PTC Academic!
