CREO 2.0 LATEST VERSION FOR STUDENT DOWNLOAD ?
SOLVED
rlangkamp
Visitor
Hello, we just watched the Robotalk video for session 4 , how do we know if we have the latest version of Creo 2.0 for First students downloaded on our computers? The last time we downloaded the files I believe it was version M070, How can I check this within CREO ? I saw on Robotalk you added a new tab in CREO 2.0 called "Schools" , I'd like to have this set up on all of our CREO software for the team , do we need to reload CREO with a newer download version to get this Tab added? Should we wait for the 3.0 version to be available ? Thx The Robotalk sessions are GREAT !
Re: CREO 2.0 LATEST VERSION FOR STUDENT DOWNLOAD ?
HI Rick,
There is a way to check by going File -> Help -> System Information. You can update by just redownloading and installing the latest image that is available.
But if you just want the schools tab, you can install it by following this guide: http://apps.ptc.com/schools/references/config_creo_schools.pdf
This should work regardless of which version you are using.
HI Rick,
M120 is build that is current ZIP file.
Welcome to PTC Academic!
