CREO 4 License problem after following the forum steps
DG1
Level 3
have deleted all my licenses, open the setup.exe, added the University students Product code BK41070..., close, run CREO and get this error every time.
Re: CREO 4 License problem after following the forum steps
your current license file is ... C:\ProgramData\PTC\Licensing\BK410705EDSTUDENTUNICL_licence.dat
Creo is looking for ... C:\ProgramData\PTC\Licensing\BE400407EDSTUDENTEDK12_licence.dat
You have to go to Parametric\bin directory in your Creo installation and correct information written in parametric.psf file
ENV=PTC_D_LICENSE_FILE-= ... this line must contain path to license file
ENV=CREOPMA_FEATURE_NAME= ... this line must contain license name (see following example)
ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student3 ()
Martin Hanák
Ok... I have read all the thread here and followed all the directions and the software is telling me that everything is exactly what it is suppose to be. Creo still will not work. I get the license error like has been posted on all the threads. What do I do now? I have reload this software 5 times and nothing works? This installing procedure sucks no directions or anything explaining what to do. Been working on this for 2 days!
it is a pitty that you did not attach picture of error message window.
Martin Hanák
Thank you a lot for the help Martin,
So, could you clarify something, should I get (from where?) the license BE400407EDSTUDENTEDK12_licence.dat and add it to C:\ProgramData\PTC\Licensing plus doing all the modification on parametric.psf as you says?
Or if I edit the parametric.psf i should not add the new license file? Is so, to what license file should I point when editing?
if you upload your parametric.psf I can modify its contents and send it back to you.
Martin Hanák
