Can't make helical sweeps within hollow cylinder? - Creo Parametric (School Edition))
Highlighted
Newbie
Hi!
I've been trying to make a helical sweep within a hollow cylinder, but for some reason the helical sweep doesn't interact with the hollow cylinder (as in it doesn't become embedded on the inside of the hollow cylinder)
the part attached should make my point clearer.
any help is greatly appreciated
PROBLEM 2:
Right now, the helical sweep can't interact with a solid cylinder either - am I using the right tool??
2 REPLIES 2
Highlighted
Re: Can't make helical sweeps within hollow cylinder? - Creo Parametric (School Edition))
If you have a school edition, none of us normal license users can open your files, sorry.
Highlighted
don't worry I solved it
Welcome to PTC Academic!
