Changing parts into BS8888 for schools
When we first installed Creo Parametric on our school system it wasn’t set up to BS8888. Unfortunately a number of our students produced parts for their final projects. We have now set up all PCs to BS8888 but when students open parts that were designed on the old settings they are not in BS8888 (even though if they start a new part they are to BS8888). I have found out how to change the parts from inches to mm but the real issue occurs when they attempt to produce drawings. The isometric view is missing.
My question is can I change a part into BS8888 after it has been completed. If not, can I add the isometric view to the parts “named view” list so the drawings pick it up?
Sam,
You are correct in your thinking. You are seeing the problem because you did not use the Academic Program template models (that contain an ISOMETRIC and TRIMETRIC view), the commercial template models you used do not.
You can fix this by adding a view named ISOMETRIC to each model. Then when you create the drawing, it will be used as you expect. To add the view:
Sam,
You may need to position the model in an isometric orientation before saving the view. Here's how you do it.
You should now have an Isometric view in this model's list of Saved Views.
Thanks to AAREng in this Eng_Forums thread for the angles used in these instructions.
