Conch shell in Creo Parametric
Highlighted
Participant
Hi all
how about this one for a problem to solve.   I am trying to create a conch shell using the helical sweep tool, I can do it so far and then I hit a brick wall namely my mathematical ability, or should I say lack of mathematical ability.  The conch shell is creted in nature obeying rules that can best be described by the using Fibonacci principles.  That is the bit that beats me.  Using the Vary Section option I can create a pseudo conch shell. See below
What I would like to do is now vary the pitch so that it changes related to the fibonacci series.  Has anyone any clues to how I might do this.  The Hel;ical sweep has a variable pitch function in Creo Parametric by setting a series of points along the profile curve axis.  If I can set the points in the ratio of 1.618 , the golden section I think I can do it.  Am I on the right track?  I attach my Schools Edition file just in case anyone else would like to play.
28 REPLIES 28
Re: Conch shell in Creo Parametric
JohnF,
I think we have some helical sweep experts (@VladimirPalffy, @GregFrankland, @ChristianSmith, @DavidButz) that may have an answer.
-Dan
Highlighted
Hi Dan
Can I contact these gods of trajpar direct?
Highlighted
You can most certainly network with them by sending a PM (Private Message) or Adding them as a friend. I sent them all a personal note asking if they could help you out when they have a free moment, also by referencing their names within a post, it sends a "Mention" notification alerting them that they may want to be part of the conversation. It's kind of like the Bat Signal
Highlighted
How do get my Bat signal to work?
Highlighted
Here's a little trick.
I'll reference you in this post, JohnF
Now, when you look at your Homepage Community Activity feed, you should see the Mention which looks something like the below. Click on the Mention tab and you'll see everything in context.
Highlighted
Interesting situation! Unfortunately I cannot read the student version to see what you have tried thus far. Can you explain a little more what you have done in the file attached? Are both the pitch and the section diameter affected by the same 1.618 ratio?
Highlighted
Hi Gregory
The spiral was created using the Helical Sweep tool in Creo Parameteric with a constant pitch but using a surface cone to which the section was locked by a tangent using tehVary Section option in the Helcal Sweep tool.  As you can see from the image this creates what looks like a conch but because I cannot vary the pitch geometrically/parametrically it does not create a proper conch spiral or equiangle spiral. The pitch needs to change by 20% per revolution roughly however the math is somewhat complex.  I think I willhave to use a Sweep and create the path via trajpar function and vary the section somehow using a relation.  So far all I am managing to do is confuse myself!!  Hope you can help.
Regards   John E Forth
Highlighted
Hi all,
I have converted the data from educational to commercial.
http://apps.ptc.com/schools/conche.prt.1
The file is Creo 1.0 Parametric.
Mark
Highlighted
We (Roger, John, Lino, and I) played around with the idea using Mathcad Prime and Creo. A Mathcad function is used to generate the Fibonacci Sequence and the (x,y,z) coordinates for a spline curve based on Fibonacci. These coordinates can then be used to generate conche geometry in Creo Parametric.
Welcome to PTC Academic!
