Copying Parameters
Newbie
Copying Parameters
I have set up a group of paramters for a model, and would like to copy those paramters to other models so that I don't need to re-write them. I read that a set of "user-defined parameters" is stored in a .dtl file. How do I create this file?
Parameters
Generally in the start-part file, all the required user defined parameters will be created . This start-part will used as a template for creating any new parts, which will contain all the required parameters. Hint : Ensure in the config file you add the path of the template file. --- template_solidpart : path. -Chander
Welcome to PTC Academic!
